FILE /home/larry/Documentation/EPS/Spread/plc_wiring.sc PLC PINOUTS All contact are sinking configuration Wed Jan 19 10:51:31 2000 IO Function TB PLC INPUT POINTS X0 Front End Shutters Closed a1,e10 (A) a0 X1 Front End Valve Closed a3,e12 (A) a1 X2 Flow #1 L5-80 a5,f1 (A) a2 X3 Flow #2 Mini Aperture a7,f2 (A) a3 X4 Flow #3 a2,f3 (A) a4 X5 Flow #4 Be Window a4,f4 (A) a5 X6 Flow #5 a6,f5 (A) a6 X7 Flow #6 Filter a8,f6 (A) a7 X10 Flow #7 a11,f7 (A) b0 X11 Flow #8 a13,f8 (A) b1 X12 Posit V5 Open a15,j2 (A) b2 MDC1 Mirror Downstream X13 Posit V5 Closed a17,j3 (A) b3 X20 Posit V1 Open a21,h1 (A) c0 Vat1 Differential Pump X21 Posit V2 Open a23,h3 (A) c1 Vat2 Mirror Upstream X22 Posit V3 Open a25,h6 (A) c2 MDC2 Filter X23 Posit V4 Open a27,h8 (A) c3 Vat3 Transport X24 Posit V1 Closed a22,h2 (A) c4 X25 Posit V2 Closed a24,h4 (A) c5 X26 Posit V3 Closed a26,h7 (A) c6 X27 Posit V4 Closed a28,h9 (A) c7 X30 Vac #1 L5-80 20 l/s a31,c1 (A) d0 X31 Vac #2 Shutter a33,c2 (A) d1 X32 Vac #3 Transport a35,c3 (A) d2 X33 Vac #4 Mirror a37,j1 (A) d3 X40 FILTER A0 b1,d9 (B) a0 X41 FILTER A1 b3,d10 (B) a1 X42 FILTER A2 b5,d11 (B) a2 X43 FILTER B0 b7,d12 (B) a3 X44 FILTER B1 b2,d13 (B) a4 X45 FILTER B2 b4,d14 (B) a5 X46 FILTER ERROR b6,d15 (B) a6 X47 FILTER DONE b8,d16 (B) a7 X200 Posit V6 Open REMOTE-IO [0] VAT-POS-OPEN PIN-G (red) X201 Posit V6 Closed REMOTE-IO [1] VAT-POS-CLOSED PIN-B (white) X202 Posit V7 Open REMOTE-IO [2] MDC-POS-OPEN PIN-4 (blue) X203 Posit V7 Closed REMOTE-IO [3] MDC-POS-CLOSED PIN-6 (black) X204 T trip Dia Mono REMOTE-IO [4] REDLION PIN-1 CLOSE X205 Ion Gauge Trip #1 REMOTE-IO [5] Clear 26 X206 Diamond water flow REMOTE-IO [6] Red 29 OUTPUT POINTS Y0 Valve 1 Close g1 (C) 0-no Y1 Valve 2 Close g3 (C) 1-no Y2 Valve 4 Close g8 (C) 2-no Y3 Valve 5 Open j4 (C) 3-no Y4 Valve 1 Open g2 (C) 4-no Y5 Valve 2 Open g4 (C) 5-no Y6 Valve 3 Open g7 (C) 6-no Y7 Valve 4 Open g8 (C) 7-no Y20 BEPS Vacuum OK e2 (E) a0 Y21 BEPS Shutter Permit e4 (E) a1 Y26 Man Ind Lamp Y27 Online Lamp Y30 Filter Motor Select d2 (E) b0 Y31 Filter POS 0 d3 (E) b1 Y32 Filter POS 2 d4 (E) b2 Y33 Filter POS 4 d5 (E) b3 Y34 Filter MOVE d6 (E) b4 Y35 Filter STOP d7 (E) b5 Y36 Filter RESET d8 (E) b6 Y200 Valve 6 Close REMOTE-IO [0] VAT-SOL-CLOSE PIN-2 (black) Y201 Valve 6 Open REMOTE-IO [1] VAT-SOL-OPEN PIN-3 (white) Y202 Valve 7 Open REMOTE-IO [2] MDC-SOL-OPEN PIN-2 OTHER CONNECTIONS FEEPS +24 V e1 (E) cA Valve Gnd g5 (C) c0-c7 +24 V e11 +24 V j9 +24 V c24 +24 V e9 +24 V (E) CB Gnd a39,a40 (A) com IV Gnd Gnd a19,a20 (A) com II Gnd a29,a30 (A) com III Gnd a9,a10 (A) com I * Gnd b9,b10 (B) com I Gnd d1 D4-22-106 Remote IO Wiring Gnd PLC-OUTPUT BUS CB Gnd PLC-POWER Gnd MDC PIN 5 Gnd MDC PIN 7 Gnd VAT PIN C (black wire) Gnd VAT PIN H (black wire) Gnd REDLION PIN 2 +24 V PLC-POWER +24 V MDC PIN 1 (red wire) +24 V VAT PIN 1 (red wire) +24 V PLC-INPUT CA Serial Connections DB9-PIN #1 PIN #1 PLC DB9-PIN #2 PIN #2 PLC DB9-Gnd Shield PLC
